Using Oil Pressure to Gauge Oil Change Intervals
Old 04-01-2009, 07:23 PM
  #21
fireball's Avatar
i've used mobil1, shell ultra, royal purple, valvoline synpower, plain castrol gtx... over the 9yrs i've had the car with a oil pressure gauge.. there is no diff in oil pressure between the oils, nor is there a diff in oil pressure from the time i put the oil in to the drainage time ~5000km later.. and this is checking oil pressure cruising on the highway at 100kph with oil temp at ~85C
so imo using oil pressure to check when to change oil is a FAIL
Old 04-01-2009, 08:11 PM
  #22
Banned
2007 Zx-10's Avatar
what's the resolution on your gauge, and what make is it? 5000 km (about 3100 miles) is not a very long OCI, so I wouldn't expect to see a significant change in viscosity that quick
Old 04-01-2009, 08:31 PM
  #23
fireball's Avatar
i have a blitz gauge and it reads oil pressure in hkpa
eg cruising on the hwy at 100kph would give ~ 5.9kpa =~85.5psi
gauge is accurate to the .1 hkpa
Old 04-01-2009, 09:42 PM
  #24
PWRMKR's Avatar
How about when/if the oil pump starts wearing prematurely? Or the bearings start to fail and babbitt starts clogging up the filter?
mayhem267
12-11-2018 11:16 PM
S2KO'd
03-12-2013 01:54 PM
kent876
09-29-2011 01:06 PM
krazik
01-11-2006 03:36 AM
Quick Reply: Using Oil Pressure to Gauge Oil Change Intervals
