Using 10w-60
Former Sponsor
Originally Posted by kaissi,May 22 2009, 03:11 AM
I'm using Royal Purple 5W-30 now. The 10W-60 was used for few months before. The question was, did it affect the engine parts that much?
Although all of our race cars currently running 5w-40, I saw TONS, TONS of F20C running 10w-60 withOUT ANY ISSUE for long term.
FYI, 10w-60 oil is very popular weight on highly modified cars in Japan.
prolux Posted on May 22 2009, 10:45 AM
jwkim Posted on May 23 2009, 03:33 AM
What viscosities do those 5W-40 oils still have after their service?
Do you know?
Do you have the oil analized?
One 10W-60 UOA I found on BITOG showed it sheared down to a 40 weight pretty quickly, within 1400 miles.
(in a Ferrari, but IMO that doesn't matter, it wasn't tracked or anything)
The people that know (on BITOG) have not much good to say about "10W-60 racing" oils.
Overpriced and not shear stable.
It would not have done any harm in an S2000, especially if it was used for a short time.
Not recommended, that's for sure.
Everything pretty much wears into a good place, so if you change oil spes you are changing that wear pattern
Do you know?
SAE 5W-30 is a viscosity range label on an oil bottle. There is nothing concrete that you can assume for actual real world operational use and wear protection from this label. The label only indicates what the oil viscosity range (cold and hot) starts out with initially. It doesn't guarantee that the oil characteristics will stay there while in use. Many don't, especially energy conserving oils.
With that being said, I have not seen a bad UOA for the F22. It appears to be pretty bullet proof as it relates to which oil you choose. But UOA's don't tell the whole story, at least for us amateurs. Only a tear down will identify what is actually happening as it relates to deposits, varnishing, coking of ring packs, etc. All of these things can hurt performance.
Honda recommends 10W-30 energy conserving oils, and 5W-40 for cold weather. Will a 5W-30 oil work for your climate? Yes. Will a 0W-30 work? Yes. Will a 10W-30 and 5W-40 work? Yes.
Do yourself a favor and start doing oil analysis if you are concerned about the oil viscosity you are using. That way you will be more comforatble with your decisions.
Hi,
I tried to check what you guys using.
I am using 10W-60 Shell And really really abuse the engine. I have broke the gearbox recently, the engine still last..
I am running Spoon ecu etc..
For example:
https://www.youtube.com/watch?v=UQNWTmS5tCU
Petr
For example:
Petr
GrandMasterKhan
12-21-2012 05:53 PM
