use V-AFC for SC electronic check valve????
Saw this quote
"...APEX V-AFC that intercepts the signal from the MAP sensor.."
in one of the FAQs
http://www.s2000online.com/faqs/showfaq.ph...?threadid=17430
WARNING! Those with an aversion to possibly dumb questions should read no further!
Can a V-AFC be programmed (or manipulated) into preventing the ECU from seeing boost on a SC engine? I went to the Apexi web site, but it's not clear if you can do this with the unit.
in one of the FAQs
Originally posted by Wesmaster
VAFC has no knowledge of boost, ................................
I've got mine wired in with a switch so I can bypass the Voltage Shunt so I can use the V-AFC to check compressor output from time to time to insure system drive integrity.
Rock, I looked and saw no obvious way to use the V-AFC as the Voltage Shunt but think it would be an easy addition for Apexi if they were to upgrade the product.
Silver S2k4
10-03-2007 04:07 PM
