UR Turbo Dyno Results
Old 11-16-2003, 05:05 AM
fperra's Avatar
Thanks SpEeDxXxRaCeR for rotating the pictures. I should have done that.
Mark, With water injection, I think 12.5 A/F across the band would be ideal, but its just a matter of how much time one wants to spend on the dyno. Of the two graphs I posted, all the tuning I did was on the first graph (9 psi of boost). On my final dyno run, I just kicked the boost up to 10 psi, but didn't change any of the eManage settings from the 9 psi run. Hence, the leaner A/F on that plot. I suspect that if I had made some more fuel adjustments, I could have tweaked out about some more HP.
I would say that without water injection, 11.5 A/F would be a better choice.
Old 11-16-2003, 06:48 PM
Banned
boostedj's Avatar
inappropriate content removed.
Old 11-16-2003, 11:58 PM
AndyS2's Avatar
What happened what did he say?
By the way very nice numbers, I really like seeing turbo setups work. Congrats.
Old 11-17-2003, 05:16 AM
beroznikmal's Avatar
nice numbers...but I think that's alot of boost for the stock compression ratio......
Good luck......
Old 11-17-2003, 07:29 AM
SpEeDxXxRaCeR's Avatar
Good luck......
It is running fine. 9-10 lbs is about right, anything more then 11 I believe is too much boost.
-Trung
Old 11-17-2003, 07:36 PM
KYS2000's Avatar
Can i ask you where you bought your WI from?
Old 11-18-2003, 02:53 AM
fperra's Avatar
PPE Engineering. You can find them here: http://www.ppeengineering.com/PPEindex.htm
Old 11-18-2003, 03:44 AM
AusS2000's Avatar
What sort of money are we talking for WI?
volcomboy390
02-27-2015 06:29 AM
ssjmikeg
10-01-2009 03:16 PM
03spa
04-12-2005 07:33 AM
HJZ
32
07-28-2004 01:55 AM
Quick Reply: UR Turbo Dyno Results
