UR Turbo Dyno Results
Spent an hour on the dyno today tuning the eManage. Here are the results:
The only adjustments made were to the Additional Injector Map. No adjustments to the timing map - all fields set at zero. Water injection system is now running two jets - a 0.6 mm and 0.7 mm. Not a hint of knocking. What really is impressive is the torque above 5000 rpm. VTEC set at 6200/6000.
You decided to use a WI system at 300 whp? Surprising, especially considering the lack of need for one, but whatever works for ya. Congrats on the quality tune!
what's with the dip at 6,600 on the 10 psi?
