Upgrading Flywheel
Upgrading Flywheel
Hi everyong,
i have a Toda 3.5kg Flywheel i was plaining to install it but need to know is it best off upgrading the clutch? or can you just use the stock one?
Thanks in Advance people.
Andrew
Andrew
Certainly if you are going through all the trouble to put in the FW you will replace all the clutch components while in there. The consensus is an aftermarket PP (Mugen, ACT, etc.) for a bit more pressure but OEM FD. Be sure to do a complete job of cleaning the parts and proper lube on assembly.
HondaGuy
11-14-2000 09:16 AM
