Upgrades or Not?
Old 05-22-2015, 05:42 PM
  #21
AZS2KDancer's Avatar
I would love to drive my S for 300, 400, or even 500,000 miles or more. I don't plan to mis-shift - I don't think anyone does. I rarely get to redline, yet I have a few times since owning it. The price for the parts was not out of line, so I'll hang on to them just in case I might need them. I think
The dual bypass oil filter system with a pre-lube pump doesn't sound like overkill to me if I want my engine to be healthy and strong at 500K miles. The kit from Amsoil looks straightforward. Other than costs of parts and time to install it, I can't think of any drawbacks to slalom44's set up.
Another product that caught my attention are the Eibach adjustable anti-sway bars. Does anyone run those? How do they accept handling and ride quality?
Old 05-22-2015, 05:46 PM
  #22
Slowcrash_101's Avatar
Pre-lube as in it cycles oil through the galleries before you start the car?
Old 05-22-2015, 07:13 PM
  #23
slalom44's Avatar
Yes. It pumps oil from your drain plug port through your oil filter, pressurizing the oil in the galleries before you press the start button.
Old 05-22-2015, 08:35 PM
  #24
Ordered my pre-lube pump.
Old 05-22-2015, 09:55 PM
  #25
windhund116's Avatar
Received 1,540 Likes on 1,044 Posts
How well do the small passages get oil, when the oil is ambient cold? Like on a cold morning.
Thanks!
Old 05-23-2015, 03:46 AM
  #26
You actually get more oil pressure when the car is cold, and really it shouldn't take more than a few seconds to build enough pressure to essentially eliminate start up wear. Once the car is hot, there's not as much wear on startup.
Old 05-23-2015, 04:57 AM
  #27
Apex1.0's Avatar
Honda is a VERY conservative company. The weak link on a Honda motor is still better than most other manufacturers. The f20c is a extremely reliable motor all things considered. There are many high mileage examples where these "issues" have never been touched.
Bottom line: you are over thinking it.
Valve retainers: If you spend lots of time at redline (track days). I would pull the valve cover to inspect the retainers and adjust the valves maybe once a year or after a possible money shift. If there are no issues, I would not touch them.
Banjo bolts: these are used to help keep combustion temps under control. The work very well. The four bolts are better but not necessary unless going to extreme cylinder pressures or temp, ie FI. Keep the coolant and oil in great shape, don't push the engine above three bars on the temp gauge. You will be fine.
Pre oiler: good idea but again not necessary. Keep good oil in it and have a oil analysis done at every change. If no issues on the report o would not worry about any of these issues.
Good luck.
Old 05-23-2015, 06:27 AM
  #28
AP1Driver's Avatar
Maintaining high revs has nothing to do with retainer failure.
Old 05-23-2015, 05:16 PM
  #29
slalom44's Avatar
Originally Posted by windhund116
How well do the small passages get oil, when the oil is ambient cold? Like on a cold morning. Thanks!
not as well as when the engine is cold for sure. But with a prelube pump, all the galleries, are full of oil and oil is already flowing through the bearings and squirting on the cylinder walls. I use 0W-30 oil to improve flow on cold starts. According to my oil pressure gauge I get around 30 psi from my prelube pump before I start the car.
The reason I installed the prelube pump was because the Amsoil Bypass filter I installed has a biasing valve that could potentially increase the length of the dry starts at startup.
Old 05-25-2015, 04:52 AM
  #30
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Originally Posted by bgoetz
Originally Posted by Billman250' timestamp='1432311583' post='23621804
Proper inspection of the retainers is key, as many people cannot see the damage. They post pictures asking, even then its hard to tell if you are not familiar.
As stated, the Ap1 retainer can go a lifetime at 9k, not much more. I have 140k on original ap1 retainers.
I would think that if the OP has had it nearly 45k miles and 5yrs if the previous owner would have cracked them he would have known by now though right? That just leaves him and if he hasn't miss shifted....
Broken retainers can go 30k or more undetected. Even when the roller rocker is grinding away the retainer and etching the cam there are no symptoms, not even noise.
Quick Reply: Upgrades or Not?
