UPDATED: Whine Noise Coming from Rear of Car
Old 05-17-2007, 06:57 PM
  #21
aero3685's Avatar
Originally Posted by 9KADDCT,May 17 2007, 10:43 PM
how does a person 'spin' the pinion bearing?
ditto.. and could a bad pinion bearing cause vibration/rattle/buzzing on decelleration?
Old 05-17-2007, 08:14 PM
  #22
Saki GT's Avatar
I'd love to hear this noise - any chance of taking a short video from inside the cabin?
Old 05-17-2007, 09:03 PM
  #23
9KADDCT's Avatar
i will try and do that today (or ASAP)
Old 05-22-2007, 06:55 AM
  #24
dmw16's Avatar
updated.
Old 05-22-2007, 10:45 AM
  #25
tekstar's Avatar
looks like oakfloor was right!
Old 05-22-2007, 03:26 PM
  #26
aero3685's Avatar
OK.. Here are some vids, the best that I could get of my problem. If anyone can see if they have the same sound.. then maybe we can figure it out.
(you will have to turn up speakers a little bit to hear) I have stock exhaust, so most/all of the noise is this vibration/rattle thing.
This first one, at about the 1.5 second mark, I let off the gas pedal all the way, and then the buzzing starts. Its about 3k rpm when letting off. It'll do it a bit more if I feather the gas letting off.
http://smg.photobucket.com/albums/v471/aer...rent=car010.flv
This one i let off at about the same spot. You can start to hear the more vibration part near the end.
http://smg.photobucket.com/albums/v471/aer...rent=car012.flv
Old 05-22-2007, 07:37 PM
  #27
CKit's Avatar
I think a bunch of people have had the same problem (myself included).
https://www.s2ki.com/forums/index.php?showtopic=490368
Does it sound similar?
http://www.youtube.com/watch?v=fsQ5Rqk8-hM
This member also had a similar problem.
His turned out to be wheel hub and bearing.
That's what I'm leaning towards. My replacement hubs and bearings are going to be installed on Thursday.
If that doesn't take care of it, the diff will be swapped Friday along with CV joints.
Old 05-23-2007, 03:50 AM
  #28
dmw16's Avatar
That is definitely not the same noise I am getting. Mine is higher pitched "cleaner" whine.
Old 05-23-2007, 08:28 AM
  #29
9KADDCT's Avatar
how much is this output bearing? any pics of it? what caused it to go bad?
Old 05-23-2007, 08:33 AM
  #30
9KADDCT's Avatar
i think this wheel hub/bearing might be my problem... i remember hitting a BIG pothole on the passenger side and right after then i started hearing the sound...
ckit, pls update me on your status.. i think you and i have the same problem..
Quick Reply: UPDATED: Whine Noise Coming from Rear of Car
