Unusual Vibration....
Originally Posted by gotswap,Oct 13 2008, 01:21 PM
I highly doubt a wheel lock is going to cause any significant out of balance issue. They are far to close to the center to have any rotational weight to them.
Originally Posted by gotswap,Oct 14 2008, 09:00 AM
So you are saying that if I run with 4 instead of 5 lugs I will have a vibration in the steering wheel due to the fact I have taken off some weight at the center?
Is there a link to the math that has been done?
I just have a hard time believing that a few gram difference that close to the center would cause a noticeable imbalance.
Normally a wheel out of balance will start at ~50 and go away at ~80mph. Or at least become less and less noticeable.
To the OP remove the wheel locks and take it for a drive to see if it makes a difference.
Well I do think that it could throw the balance off because they were noticebly heavier. Plus I didn't have the issue before.
It does not effect the steering as said before but sure as hell has a slight vibration at higher speeds that does NOT go away abve 40mph. I went up to 90mph to see. Still there.
Process of elimination. Put your orignal lugs back on and see if the vibration still exists. If it does, then the locks aren't your problem.
Is it possible that a wheel weight got knocked off when they were messing with your wheels? If so, you need to get your wheels rebalanced.
dailodailo
10-18-2003 09:41 AM
