Unusual Vibration....
Old 10-12-2008, 02:40 PM
EOE
EOE's Avatar
Default Unusual Vibration....
So I installed wheel locks right after some one made an attempt to steal my rims and my alarm woke me up. I came out to all lugs off, 1 wheel off with jack and tools still next to my car and bricks underneath it.
Could wheel locks possible throw off the balance if they are heavier than the lugs? I now get a vibration that increases from 40mph and on. It isn't felt in the steering wheel but more in the shift knob/body of the car.
Never had vibration issue on any of my vehicles with out having it mess with the steering wheel. So weird...
Old 10-12-2008, 03:59 PM
Slows2k's Avatar
You check to see if all the lug nuts are tight?
Old 10-12-2008, 05:48 PM
EOE
EOE's Avatar
Oh yes, Torqued them down to 80 foot pounds as well. Im anal about stuff like that.
Old 10-13-2008, 06:31 AM
devilchrist's Avatar
from past when you have vibrations after a certain speed, 40 like you mentioned I found them to be from off centered wheel mount.
I'm not sure how s2k's mount their wheels but alot of vehecles i've owned has a hub centric ring. anyone s2k owners confirm this?
Old 10-13-2008, 08:10 AM
EOE
EOE's Avatar
From what I understood the stock wheels don't need them. I could be wrong. But on my Prelude when I went with aftermarket rims, I needed to order the rings as well. But stock wheels did not need them.
Old 10-13-2008, 08:16 AM
cdelena's Avatar
Yes, wheel locks that weigh more can through off the balance.
Old 10-13-2008, 08:51 AM
gotswap's Avatar
Have the wheels checked for balance, they may have also put your alignment out of whack if the car was dropped on the rotor.
Old 10-13-2008, 11:00 AM
EOE
EOE's Avatar
Im thinking wheel locks.. The car wasnt drop, I checked the surrounding area and the rotor.
How the hell am i gonna fix the wheel locks issue now.. greeeat
Old 10-13-2008, 11:21 AM
gotswap's Avatar
I highly doubt a wheel lock is going to cause any significant out of balance issue. They are far to close to the center to have any rotational weight to them.
Old 10-13-2008, 11:48 AM
EOE
EOE's Avatar
Hmm true... I wounder if the fact that the car was completely on the ground on one side with all lug nuts off, wheels on and other side jacked up had anything do with it.
Basically all lugs were off and when I put the wheel back on, lowered the car, then went around putting lugs back on and torquing them down to 80.
Quick Reply: Unusual Vibration....
