Unknown rattle somewhere in dashboard
Old 03-02-2014, 02:12 PM
6480jojo's Avatar
Default Unknown rattle somewhere in dashboard
Hello guys. Last week i bought my first S2000 MY00 with 148XXXkm on it. My car has a rattle somewhere in dashboard on certain RPM. Between 2000 and 5000 it start to rattle. No matter if i drive or i dont move or if the clutch is in or out. When i brake hard the noise change a little bit like the thing that rattles change its possition, but i cant hear the change of possition(if it does) only the sound is slightly different. You can slightly hear it even when idling and also it is hearable near engine. I recored a video so you can hear it. Thx guys.
RATTLE VIDEO
Btw this is my S2K
Old 03-02-2014, 03:08 PM
Saki GT's Avatar
Does it rattle when your sitting still or only when you're moving?
Old 03-02-2014, 03:10 PM
6480jojo's Avatar
Also when i sit still and rev no matter if clutch is in or out. You can see it on video
Old 03-03-2014, 01:14 PM
6480jojo's Avatar
Help please. The rattle is clearly hearable on the video. Thanks guys
Old 03-03-2014, 01:18 PM
fernando.'s Avatar
Check the bolts on the side of the dash when you open the door, they're behind a little flap. Mine backed out make everything rattle.
Old 03-03-2014, 03:42 PM
Utah S2K's Avatar
Might want to try having a passenger put pressure on different areas (I.e. Brackets, panels, etc.). If it loose touching it will change the vibration frequency and you will find it.
Utah
Old 03-04-2014, 08:35 AM
6480jojo's Avatar
Today i checked the side bolts. They were loose but i tighten them up and it doesnt help. Tomorrow i will try what you said Utah.
Old 03-05-2014, 03:32 PM
6480jojo's Avatar
So i was trying to determine where is it coming from. I can clearly hear it when i have my head near the pedals, but i think it is not coming from dash but from the bottom of the car. It is hard to find out since the car is too loud when i press gas to start the rattle. And also i was braking down the hill to full stop and every time i was about to stop it sounded different from normal. Like some screw or metal ball or something is rolling there. It did every time i pressed the brake but it was not related to the brakes... Tomorrow i will try to check heat shields but i think it is not the reason it rattles
Old 03-06-2014, 01:47 AM
SmokeyGatto's Avatar
had a similar rattle, it was a loose bolt behind a plastic cap on the left side of the dashboard. it can only be accessed if the door is open an the cap is removed. I removed the cap and the bolt fell out, tightened it back up and presto, no more rattle. Hope you're as lucky as i was.
Old 03-06-2014, 10:31 AM
6480jojo's Avatar
Thanks but it is not the one. None of those which can be accessed from the interiour. Today i was checking underneath the car and nothing is loose there. Not a CAT and also the heatshields are ok.
Maybe something in the ventilation? Some bolt or something???
Quick Reply: Unknown rattle somewhere in dashboard
