Uneven steering effort/ resetting torque sensor
I've followed the steps and tried to read up on the resetting procedure but doesn't seem to be do anything. After I follow the steps the EPS light keeps flashing in a sequence when done. Should the EPS light be blinking for be completely off. Once I remove the the paperclip and start the car the EPS light goes off. Does that mean it's been done correctly? Any tricks to this?
Just follow the instructions.
-- Chuck
Torque Sensor reset procedure:
With the car off, and the wheel straight do the following Using a paper clip or backprobes, connect PIN 9 to PIN 4 on the ODBII connector.
If the EPS light stays on, you will have to do this process again.
- Turn the steering wheel 45 degrees to the left
- Turn the ignition switch on (II)
- The EPS Light will be on for 4 seconds, when it goes out do step 5
- Turn the steering wheel Straight, and release
- The EPS Light will turn on in 4 seconds, when it goes out do step 7
- The EPS Light will be on for 4 seconds, when it goes out do step 9
