Under The Hood Squeak!
Hi,
I have found a squeak which I could hear in the cockpit any time that I driver over bumpy roads. I cleaned the hood latch and sprayed it with WD-40 but it only solves the problem temporarily and the squeak returns. In the meantime, I have purchased some black grease but I do not know where to place this any ideas where to place the grease so that this squeak does not continually return?
It is driving me crazy!!!
WD-40 is not a true lubricant. It's a cleaner. By using it, you probably clean off what lubricant there was on the latch assembly. For such applications, you need to get "white lithium grease". Spray it on the part of the latch that catches the hook on the hood and any other moving parts in the latch.
You probably need to also adjust the hood stop bumpers.
IIGQ4U,
I had a very similar problem with my MY 04. Mine ended up being related the hinges that hold up the hood at the windshield base. I finally diagnosed iti by propping the hood, then wiggling it in propped position. It turns out I could hear the squeeking. To remedy I tighened the bolts holding the hinges in place and the squeeks were forever gone. Try it and see if it helps.
Regards,
Christopher
Regards,
Christopher
I removed the 3 bolts altogether and reinstalled, the squeaking returned. I am just going to purchase one of those grease guns and grease that whole friggin latch.
Actually for now, the squeak is gone and has not returned for a day I lubed it again with a different product although if it does return I will utilize the grease gun method.
Thanks for your help guys.
Thanks Xviper, but like I said, I have already purchased black all purpose grease. To apply the black grease I need something like a large syringe (which I am having trouble finding) or a grease gun.
Originally Posted by IIGQ4U,May 16 2006, 02:05 PM
Thanks, but like I said, I have already purchased black all purpose grease. To apply the black grease I need something like a large syringe (which I am having trouble finding) or a grease gun.
Where do you purchase the white lithium grease? How is it applied? What is so great about this White Lithium grease anyway?
Reminds me though Incubus the rattling didn't begin until I raised my hood latch. I raised it because I could not drop the hood shut. I had to drop the hoop and then press it closed. I can't seem to find the sweet spot.
