UK AP1 (2002 reg) Idle issues
Thanks for the reply Billman250,
I am not in anyway knowledgeable about where the more technical things are.. I am fairly confident that it hasnt been drilled/bolted, i will see if i can find a pic of what i am looking for and go check!
Weird question but i feel it may be relevent.. is it possible to adjust the TPS without it being drilled? with software maybe?
Cheers
Cheers
This is a long shot, but did you have your alternator checked? Is it possible these are signs of the alternator going bad? You mentioned a dimming of the dash, which is why I am mentioning this.
If your alternator is not working properly and you add electrical load (ie A/C, stereo, headlights, etc.) it will draw power from the injectors causing them to run at 11-13 volts. The ECU should compensate for this, by making the injectors staying open longer. Thus allowing more fuel to be dumped in. The power should be restored to normal operation of 14 volts rather quickly.
Is it possible the alternator is failing causing the injectors to stay open too long, thus flooding the engine causing a stall?
I stand corrected Billman, you sir are a wizard!
It would appear to have bolts on! below is a pic of the top bolt. Appears non standard to me..
https://www.dropbox.com/s/yynlrqeegx...2014.56.12.jpg
How would i go around fixing this?
Thanks
Thanks
Hi Geebs,
thanks for your reply!
I have not checked anything to do with the alternator... Hadn't thought about it really!
How would i go about checking this?
Cheers
Cheers
Oki,
Noob question but I am not overly sure how to adjust the tps?
Any pointers would be hugely appreciated! I should have time over the weekend to give it a good go!
Cheers
Sent from my iPhone using Tapatalk
Cheers
brian87108
03-29-2015 10:45 PM
goravens
10-29-2013 06:58 AM
