turning signal doesnt work
Just got my car back from a clutch job and a hour later I noticed that my left, right, signal does not come on when i engage it and neither does my hazards works. Theres no signal inside or outside the car. Also, I cant drop my top as well. I'm sure its two different problems that i'm dealing with. I checked both fuse boxes (in the engine bay + under stearing wheel) and they both seem to be okay.
Has anyone had a problem with this before? any help or suggestion are appreciated.
thanks.
thanks.
Did you check fuse #49 (10A) in the underhood panel?
Did you check fuse #7 (7.5A) in the underdash panel?
Did you check the flasher/relay in the underdash panel?
There are 3 separate fuses that have to do with the convertible top in the underdash panel and 2 fuses in the underhood panel.
Do the bulbs light when you move the stalk or hit the hazard button? If so then it's probably the flasher.
If the top also stopped working at the same time, then your mechanic probably borked something; make him fix it!
Originally Posted by Slows2k,Apr 17 2006, 03:38 PM
Pull the console up and plug the hazard switch in.
I'd bet they didn't plug it in when the shifter was out.
Originally Posted by Slows2k,Apr 17 2006, 09:18 PM
The console pops up in about 5 seconds. It's easier to check the hazard switch that pulling all of those fuses.
You'll hate it if I'm right.
I had the same thing happen to me when I forgot to plug them back in.
No big deal.
The problem was the connection. The mechanic did not make the connection tight enough and it got loose. I dont understand y honda would put the top controls on the same series as the turning signals.. anyone know y? just curious.. everything works now.
thanks all!
