Turn Signal Not Working
Hey guys and gals,
Short back story here, several weeks ago the 10A fuse that controls the dimming of the guage when the headlights are on and the taillights working blew out. I replaced it and then two weeks later it went out again. I replaced it. A few days before it went out the second time I noticed my right side turn signal flashing quickly. The front turn signal does not blink. I buy replacement bulbs and get to pulling out the old bulb. Old bulb looks fine but I put the new one in anyway. Still doesn't work....Could those two be related and what do I try now? Thank you.
I can't think of how they would be related, as they are different circuits and different fuses.
The turn signals flash fast if the current is too low, which is caused by either a burned out bulb, bad bulb socket, or a loose or disconnected wire (going to the bulb). Since you changed the bulb and it doesn't light there must be a bad socket or the wire between the turn signal relay and the socket has an open somewhere.
The parking light fuse blowing is another issue. That fuse powers the tail lights, front markers, license plate light, and all the switch and dash lamps in the interior of the car. That's a lot of locations to go looking for an intermittent short to ground or something pulling too much current.
Have any other bulbs been replaced? Any crash damage that could have crushed a wiring harness? Trailer hitch harness added? Is there anything else electrical that does not work properly? Have you checked to be sure all the proper lamps (and no others) come on with the parking lights?
SweetWaterSurprise
03-21-2016 08:09 AM
s2cho
09-26-2013 05:52 AM
YDNA
09-30-2012 12:11 AM
