Turn Signal Help
Turn Signal Help
I just went to change my turn signal bulb in my '02. Now when I turn on the right turn signal, it flashes fast, and when I turn on the left, it flashes normal. I changed the rear bulbs, and the right rear no longer turns on. Tried changing back to the stock bulbs, and the right rear still doesnt flash, but the front and side still flash fast. Any ideas what this could be?
I found out that it was a bad connection on the rear bulb, I guess when I pulled the origional bulb out, the power tab must have crimped a bit, to where it wasnt touching the bulb. I switched to a smaller bulb so the lights will blink faster, but I need to find a more white bulb to put in there so it will match the front PIAA plasma white's.
Hi, my problem is NOT the same as the OP. but didn't want to add a new topic.
But I am having problems with my turning signals too, but its not permanent, sometimes they work, most of the time they don't.....
i hear it click (flasher) but NONE of the turning lights work (dash turning lights, RR,RF,LR,LF,) nor the hazards...
I've had an all LED Turning lights system for over a year now with modified OEM flasher, and have never had any problems till a couple days ago...
if its fuses i would think they would never work right?
thanks in advance for the help
