Turkey basting brake/clutch fluid--does it work?
Old 06-29-2015, 12:29 PM
HarryD's Avatar
Originally Posted by dedonderosa
watch this video. i know people who have been doing this for years and never had a issue for the clutch
https://www.youtube.com/watch?v=gBbsy0LjUvE
So clutch fluid has more movement (due to the pedal movement or just how the master/slave work here)?
If you think about it--brake fluid contaminants and moisture settles at the lowest point of your braking system and does not circulate much (if at all) back into the reservoir--the lowest point is also the most important point, right where your brakes/calipers are, so cleaning the reservoir alone is NOT good enough.
As a science experiment, I bled my brakes for the first time in three years yesterday--the front two wheels were fine, but my back two wheels had fluid that was darker/cloudier than I can tolerate. My reservoir fluid was brand new, however, since I've been turkey basting it every 3 months for 3 years.
So mystery solved, case closed. Merely turkey-basting your brake reservoir is NOT good enough. Bleed your brakes folks!
Thanks!
Memo6453
07-23-2014 09:41 AM
kwakhead
04-03-2014 08:53 AM
doug44
06-19-2012 10:08 AM
ls1->s2k
02-02-2012 03:52 AM
bunjimobile
10-18-2004 08:12 PM
Quick Reply: Turkey basting brake/clutch fluid--does it work?
