TurboS
The only two companies that have sold more than one or two turbo kits include Speedcraft, Stage VI Motorsports, and Ultimate Racing. Speedcraft has gone out of business. Stage VI was founded by the guy who designed Speedcraft's kit before heading out on his own. http://www.stage6motorsports.com/ I'm sure if you do a search on Ultimate Racing, you can find posts regarding their kit here on the boards.
CB
CB
Good luck with your kit. Hopefully you manage to build a good one and with good success. There are not too many of us that have had good results with Turbos. I like to see success and not failure..
Air/water intercoolers are ideal for drag racing, not street use. Heat soak is very bad if the car is not moving with an air/water. The reason it is ideal for drag racing is because you can use chilled ice water.
From a PM I sent in response to one of many I get about my turbo kit: "It's not something I would do unless you're prepared to spend three times what you think it'll cost and take six months longer than you expect." Bottom line: the S is already engineered reasonably close to the limits of performance, so adding a turbo is no trivial task. That said, I love my setup. I had no trouble dogging a 911 Turbo at Pacific Raceways in Seattle in October for several laps until the driver got frustrated and gave me a point-by. But it was a lot of work, time, frustration, and money to get there. If you want the full story, do a search on my screen name. You'll see a story littered with a series of minor setback and problems, some of which I'm still sorting out.
CB
CB
And keep in mind... Its a boosted Honda, its not "IF" it will blow up its "WHEN"
