Turbo Retuned with eManage Ignition Control and Boost Upgrade...
Old 08-08-2003, 07:31 PM
Wesmaster's Avatar
Default Turbo Retuned with eManage Ignition Control and Boost Upgrade...
The car was recently equipped with 440cc injectors and we got the eManage ignition timing working. I told the tuner to tune the car to his desire, as he saw fit, as he is a very experienced turbo Honda tuner (and fabricates his own kits). I know that some people will say the boost level I'm running is stupid, but I've accepted the risk and I do know the risk. I'm relying on the expertise of my tuner. The results are 321 whp on 11 psi on 93 octane. The car is much faster, much. There are a few bugs that we need to work out, but the car is driving very well.
Old 08-08-2003, 07:36 PM
mbitton's Avatar
What else is done to your car? Exhaust? What size turbo are you running?
Thanks
Old 08-08-2003, 09:11 PM
Stale_Hotdog's Avatar
Awesome! What I'm really impressed with is that you're not running stand alone and from what you said it's running well. to your tuner too!
I wish my s2k was as fast as yours.
Old 08-08-2003, 09:14 PM
CMiS2K's Avatar
why doesn't the torque stay at a constant? the chart is all over the place.
Old 08-08-2003, 09:17 PM
Steve@Evolution's Avatar
wow, your torque dropped hard after 8200 rpm. Are you miss firing?
Old 08-08-2003, 09:19 PM
CMiS2K's Avatar
the torque is down hill after 6k.
Old 08-09-2003, 06:03 AM
SC-SUZUKA's Avatar
Great numbers. Wes, so now does it feel faster than your SC set-up?
Chris C.
Old 08-09-2003, 06:12 AM
turbo_pwr's Avatar
Ok, damn you build a lot of your power in the mid range. It almost seems like it's not even worth taking the car up to 9k anymore.
Old 08-09-2003, 07:56 AM
Wildncrazy's Avatar
Why'd the dyno run start at 4500?
When did the boost start to build? The major advantage of a turbo over a SC is more boost earlier and longer so curious minds want to know
Since you "only" made 321 hp at 11 psi (several are making 300 @ 8 psi) and with the torque fall off I am guessing you are running out of the turbo's efficiency range on the upper end. That is not a complaint or a dig in any way. That type of set up would be better on the street than a larger turbo and obviously would also work well at the track.
Could it be the torque & power fall off from 6-8k are because the stock ecu is still cutting timing in huge chunks on top of the eManage? Anyway to confirm that? Maybe a little more work on the ignition side could solve that.
I wouldn't expect it to be perfect the first time out on a new system, but it looks pretty awesome!
Old 08-09-2003, 09:04 AM
[QUOTE]Originally posted by David b
[B]Since you "only" made 321 hp at 11 psi (several are making 300 @ 8 psi) and with the torque fall off I am guessing you are running out of the turbo's efficiency range on the upper end.
Quick Reply: Turbo Retuned with eManage Ignition Control and Boost Upgrade...
