Turbo guys, what do you run?
I was told that running low boost (7psi) I would only need a 2.5" exhaust. Do you think this is sufficient? Or should I still get a 3"?
If your going dual exhaust run 3 inch till it spits then run 2.5, other wise if your going single exhuast run straight 3 inch.It also depends on how much power your planing on making and which turbo your using.
Originally Posted by Hobbyholic,Dec 6 2004, 08:44 PM
I am running a 60-1 with a 2.5 exit then 3" all the way back with the Apexi n1..
Originally Posted by TurboVtk,Dec 6 2004, 10:50 PM
i think HKS ti. sounds best.
- I tried to switch the mufflers (HKS instead of n1) but it was too late, exhaust already made
