Turbo boost vs. Compression ratio
Old 03-13-2003, 08:54 PM
diGital.James's Avatar
suzuka, those mods won't help against detonation. the best thing you can do to prevent catostrophic engine failure is
a) make sure your car is not boost spiking. (get a boost gauge) no radical free flowing mods.
b) make sure youre running stoich. (get a EGT gauge) rich is better than lean. start rich tune progressily leaner. fouled plugs are better than blown motors. timing retrads are a plus. j&s knockgaurd is also a very good product.
c) take care of your car! always be on the lookout for problems. blown of vacum lines can cause be headfaches. (zip tie them suckas) make sure youdont have oiling probs, make sure you have clean fuel filters and injectors comsistantly, i can't stress this enough (get a fuel presure gauge).
RavorV3,
My rx7 is still my favorite car ive owned....it was the best, 11.27 et in the 1/4 and 1.03 g's on the skidpad. 'nuff said.
Old 03-13-2003, 09:25 PM
SuzukaS2K's Avatar
[QUOTE]Originally posted by diGital.James
[B]suzuka, those mods won't help against detonation.
Old 03-14-2003, 08:46 AM
look out for any rise in temp once the car is warmed. the needle should be planted on throttle. there wil be soime fluctuating during idle. if you see a rise in temp, back off.
Old 03-14-2003, 11:00 AM
wicky's Avatar
[QUOTE]Originally posted by RazorV3
[B]
well the RX7 IS a POS, so it would've happened anyways.
Old 03-14-2003, 08:20 PM
RazorV3's Avatar
rx7's are sweet cars but i can't believe the hell my brother went though just to maintain his tt rx7. he also had the apex seal problem, and his manual transmission was junk. it wouldn't even go into REVERSE! he now has a 98 CW ITR and he loves it more than the RX7, even though its much slower.
Old 03-14-2003, 09:13 PM
wicky's Avatar
rx7's are like the japanese version of an italian sports car. Fast from a launch, quick in the turns, takes no guff from any other car, and breaks down at least once a week.......I loved mine, but I wanna build my car up, not fix it up..... mine would go into reverse, but not first.... rebuilt the transmission twice..... oy!
Old 03-14-2003, 09:15 PM
SuzukaS2K's Avatar
RX-7's are sweet car!! From inside to outside I will give it a 10! Downside is the break down.
Old 03-14-2003, 09:19 PM
wicky's Avatar
diGital.James - what compression are you running on your new motor and what psi are you aiming for?
Old 03-15-2003, 07:16 AM
phaco's Avatar
Did you remember head gasket thickness volume?
It was less than 11:1
Old 03-15-2003, 07:44 AM
Porsche518's Avatar
You can run as high of compression as want, heck some the import drag cars are ruinning 14:1 plus compression with crazy boost. It all comes down tuning, you have to use the right type of mangement (Vafc and 9.5 compresion and is not a good idea). Stand alone with good tuning you can run hard on boost with high compression.
skool u
07-27-2015 11:09 PM
spdracerut
04-08-2015 05:52 PM
Peter@ISP
02-11-2007 03:50 PM
BulldogS2
10-16-2006 09:09 PM
S2peed
11-25-2001 07:39 AM
Quick Reply: Turbo boost vs. Compression ratio
