Tuner in Austin, TX
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Hello folks:
I am nearing completion of my 1964 Triumph TR4 with f22C engine/trans install. I am looking for a tuner in the greater Austin Area to take it to and get it dialed in.
I need someone that can think a little out of the box 'cause I'm not using the usual ECU's.
Any help would be appreciated.
Rod
Engine:
2005 F22C Darton Dry Sleeves
Urge Designs headwork
Urge Designs ITBs
Custom 4:2:1 Header
Emerald K6 ECU with Innovate LC-1 wideband
No Cat- (not required for 1964 car).
![Name: TR4%20engine%20left_zpsb107peaz.jpg
Size: 294.8 KB](https://www.s2ki.com/forums/attachments/s2000-under-hood-22/78568d1501262013-tuner-austin-tx-tr4%2520engine%2520left_zpsb107peaz.jpg)
Rod
Engine:
Urge Designs ITBs
Custom 4:2:1 Header
![Name: TR4%20Frt%20Left%20w-top_zpspngkadqu.jpg
Size: 1.18 MB](https://www.s2ki.com/forums/attachments/s2000-under-hood-22/78569d1501262013-tuner-austin-tx-tr4%2520frt%2520left%2520w-top_zpspngkadqu.jpg)
![](https://www.s2ki.com/forums/images/s2ki/ranks/com_organizer.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Have you posted in the local Central TX forum?
If I can't find someone I trust in Austin, I'll trailer the ca to Houston or Dallas. I have found a couple guys that I wouldn't let tune my niece's tricycle.
Rod
Rod
Also, for having access to an engine bay that is as large as that, why the **** would you put the engine so far forward of the front axle?
I know why. It's because 'bros, check out my sweet F2X swap'. Cuz the internets. And coolness.
