TSB 054 clutch, is this the "improved" 2002 clutch?
Old 06-13-2002 | 04:47 PM
peterpan's Avatar
Originally posted by Freakaccident
They are replacing the whole tranny for the grind problem?
Only If they can't fix the grind I guess.......
I know one North Tx S2k owner (00my) he got a new 02 tranny because his tranny grinded BAD.
Old 06-14-2002 | 07:02 AM
Gernby's Avatar
Former Sponsor
I have an '02 that grinds into 2nd gear just about every day. I have done several things to reduce the grinding (clutch pedal adjustment and oil change), but I don't think the '02 tranny is really "All That".
I also think the '02 clutch is weak as hell. My engine is basically stock, but I have never been able to generate wheelspin in a straight line (Once the clutch just burned freely up to Redline), and it takes a second or so for the clutch to grab in 2nd and 3rd.
Old 06-17-2002 | 07:46 PM
Silver02's Avatar
I must be very lucky! My 02's clutch responds like I would expect it
to. No delay in shifting, hits hard in every gear, leaves S02 marks on
demand.
Old 06-17-2002 | 09:31 PM
Everett's Avatar
Hi All!!
I need some documentation, where is specifies that 054 TSB applies also to 2001 models.
I saw the bulletin, dated Decembre 2000, and it does not specify it.
Thanks all.
Everett
Old 06-18-2002 | 11:53 AM
bbsilver's Avatar
[QUOTE]Originally posted by Everett
[B]Hi All!!
Old 06-18-2002 | 04:28 PM
CMiS2K's Avatar
gernby,
I agree with you also, my ,02 is the same way, you were at the BMW event and I saw and heard your tranny, neither of us could get the clutch to hold a dump. I have the 2nd gear grind also, I am going to look at my actual build date on the door panel, there is a possiblity we could have early '02's produced with '01 parts, just aa thought. my vin is 4848.
Old 06-18-2002 | 04:34 PM
CMiS2K's Avatar
ok just checked 03/02 build date. We need to face it, they have saved costs and put in a weak clutch and rear end. I'd pay the extra 2k if it came from honda as a higher end clutch/tranny and a rear end that wasn't designed in the '80's from Mazda.
stage 3 clutch, fly wheel and reinforced upgraded rear end are all about 2k, this is the answer now.
Old 06-18-2002 | 04:41 PM
kjs007's Avatar
What all do they replace on this TSB?
Old 09-17-2002 | 05:51 PM
Ted's Avatar
Ted
I picked up my 02 on Aug.26 '
and I have the 1/2 grind problem
Old 09-17-2002 | 07:34 PM
boiler's Avatar
TSB 054 calls for the replacement of just the clutch disk. After mine was replaced recently, it feels/drives the way that it should have to begin with. It seems to grab very well, now.
You'll like it,
Bob
Quick Reply: TSB 054 clutch, is this the "improved" 2002 clutch?
