Trunk Lid Won't Open
Randomly, my key fob will not open the trunk nor will my passenger door automatically lock/unlock. I've replaced the key fob battery and still the issue remains. Also, I'm not too sure if this is normal but when I turn my headlights on, it dims the lights inside my car when driving at night. But during the day, the my speedometer lights is brighter when the headlights is off. Shouldn't it be the opposite?
Help!
Help!
Push and hold the dash light brightness control for a few seconds and the dash will go full brightness with the lights on.
Are you holding the trunk button for a few seconds? It has a time delay so you do not accidentally open your trunk if the button is pushed by something in your pocket.
I would check your trunk open mbutton inside the car. If that button works fine something is wrong with your key fob. If that button doesnt work sometimes as well, your trunk opening mechanism has problem.
About the brightness of your dash, it's in the manual that with the headlight on you can make it full bright by holding the plus sign.
- Johnson
Check to see if the trunk is getting a signal. I believe it is two wires. One hot one ground. One will remain all the time and when you push the button the other will send the signal.
Very easy to test. If there is no signal test at the button to see if there is power. That won't be easy as you might need to remove the console. If I remember the loom runs up the driver side shelf and might be able to test there. The plug pops out I don't remember if it is tight or not
Received 1,744 Likes
As far as the instrument lights go; they may have reset after loss of power during battery change. You can set both daytime and nighttime (lights on) intensity levels.
