Trunk Latch Assembly
Originally Posted by Utah S2K' timestamp='1361852392' post='22363735
The trunk circuit is also connected to the keyless door lock control unit. Q1- Does your kekless lock function work? If not check fuse #26, it's Located under the dash on the main fuse panel. Right side second fuse down. If door lock works it's either the trunk switch or trunk solenoid. Frankly I have seen this mode twice and both cases were fixed by re seating the connector for the trunk solenoid. 3 pin rewarded next to the trunk latch. Obviously came loose during trunk opening nag and closing.
Utah
Utah
If the switch is OK then you can move on to the latch assembly. This is a little tougher. Grab a 12 volt battery or power supply and briefly connect pins 1&2. If the solenoid does not actuate the latch replace the latch assembly.
Replacing this assembly requires disconnecting the 3 pin connector, removing 2 screws, and twisting the assembly 90 degrees clockwise to disengage the latch pushrod.
Replacement torque is 7.2 lbf.ft if you end up replacing the latch.
Utah
