Trouble starting 2.2 in ap1. Crank/cam pos sensor
Hi Guys,
I'm having trouble starting my car and I've traced it to the Crank Shaft Position Sensor (CKP). First off, the car is bit of a mutt:
I found someone with the same symptoms, however AFAIK (car was swapped before I bought it), my engine hasn't been taken apart and it runs strongly, so I doubt the cams are off by a tooth.
From reading this thread, I know the cam sensor and wheel changed in 2006 for the DBW cars, and they need to match each other. I believe (but am not sure) both of mine are from the 07 engine. Does the crank position sensor and wheel need to match the ECU as well? I'm thinking I may need to install the 2000-2006 (non-DBW) CKP sensor and wheel to match my 2004 non-DBW ECU and throttle body.
Also, are the camshaft position sensors different between 00-05 and 06+? Could that be my problem?
Thanks for any help!
- 2002 Chassis
- 2002 Intake Manifold & Throttle Body
- 2007 F22C Engine (DBW)
- 2004 ECU (Non-DBW)
Based on your troubleshooting steps, It sounds like the ECU needs to match the DBW engine/sensors.
the non-DBW cars have two cam sensors on the head; the DBW cars only have one if I remember correctly.
Hey, I think you are right. I saw this thread and his swap is the opposite (F20 in an 06) but his symptoms are the same.
On his car, with a crank sensor and wheel that match his F20 but not his 06 ECU, he gets a P0339 CEL. On mine, I can trigger a P0339 if I hold it around 50% throttle near 8000 RPM. As the revs climb, it'll slow down at 8000, like a soft revlimiter, and throw a P0339 after a few seconds. Full throttle lets me climb to 9000, which also triggers a P0339.
About the cam sensors, it looks like I have the old 2002 valve cover. I definitely have 2 TDC sensors instead of one.
