Transmission weight
Old 05-23-2010, 11:58 PM
SRap1's Avatar
Default Transmission weight
I need to get a trans down to under 100lbs (TOTAL, INCLUDING CRATE) so that i can have it shipped via usps.
I want to know what can be removed from it... tail shaft, shifter etc...
The items that are removed will be shipped seperate, as USPS will not ship anything over 100lbs.
Old 05-24-2010, 04:31 AM
Slows2k's Avatar
Ship it UPS?
I've shipped 2, both weighed 105ish pounds in a box built around them.
Old 05-24-2010, 06:28 AM
SRap1's Avatar
I have to ship it USPS, as im military stationed overseas...
105 huh? i wonder if maybe a less heavy box could be used... by the way im not shipping it: its being shipped to me and it needs to be under 100 lbs total, if i had the trans here i wouldn't ask i would just start taking things off and see what it saves.
Im just trying to help out the seller so i can get the trans shipped over here.
Old 05-24-2010, 11:28 AM
AngryTurtle's Avatar
Originally Posted by Slows2k,May 24 2010, 08:31 AM
Ship it UPS?
With or without fluid?
Old 05-24-2010, 03:41 PM
Slows2k's Avatar
Without
Old 05-24-2010, 04:26 PM
Billman250's Avatar
Received 1,402 Likes on 839 Posts
The tail shaft can easily come off as one piece. you dont even need to remove the flange
Old 05-24-2010, 09:15 PM
SRap1's Avatar
BILLMAN250: thats what i was thinking too, any idea of the approximate weight?
SLOWS2K: What box did you use? did you make it?
Old 05-25-2010, 04:27 AM
Originally Posted by Slows2k,May 24 2010, 07:41 PM
Without
lower.
Old 05-25-2010, 04:09 PM
Billman250's Avatar
I could weight it for you tomorrow i have one off
Old 05-25-2010, 04:58 PM
Slows2k's Avatar
They are around 90 pounds no box. I took a much larger box and sectioned it around the trans.
Quick Reply: Transmission weight
