transmission sounds loud
i've noticed that my transmission is pretty loud. like i feel like i can hear the gears spinning right underneath my shiftknob. not sure if this is normal or not, but haven't had the chance to sit in another s2k to compare.
i changed the transmission fluid, didn't help. apologize for the crappy description, not sure how to describe it. will try to get a video this weekend
mine makes a bit of noise too that stops when i depress the clutch if im sitting at nuetral. But its subtle, hard to make out unless you really listen for it. Its not uncommon for trannys to make noise or whine a bit but if it gets bad then have it looked at.
tohlenforst
09-24-2018 07:36 PM
