transmission separation problem
I'm trying to separate my transmission from the engine but it only separates about 8mm @ the top an sides, btw I removed all bolts and clucth release fork. I have been reading about input shaft binding, any recommendations please?
Remove the clutch slave cylinder. Pull the clutch fork outwards, step back to avoid the gearbox dropping on your foot.
The S2K has a pull clutch. The clutch fork pushes into a slot on the thrust bearing which is pulled through the pressure plate.
silvermonster
07-16-2012 09:50 AM
