Transmission noise after tranny swap
My friend swapped an f22 with ap2 tranny in his ap1. he has been having a weird noise from the transmission tunnel. all bolts are tightened. A mechanic told him that its probably because he put in a 9 lb flywheel and the engine is unbalanced now. i dont think that would be it.
another person told him he might be missing some piece of insulation on the black piece where the shift knob is. Is there a rubber seal or something that goes there? he does not remember his old tranny having anything there
#5 is rubber and mounts to the tranny tail section and to the body on the underside of the car.
#9 is rubber and is part of the shifter (I doubt you are missing this one)
#6 is rubber and mounts over the shifter and to the body from inside the car.
![](http://www.hondaautomotiveparts.com/auto/jsp/mws/catimgs/14s2a01_b34.png)
From what I've heard, #12 in that diagram is known to reduce a lot of mechanical noise in the cabin from the trans tunnel but I'm guessing you're having an issue with a new noise that can be heard inside or outside the car?
(note that I put in 2005. dunno if there's a difference between the years but you should be able to find it under "SHIFT LEVER" on that site)
