Transmission leak
Transmission leak
For the past couple of months I have noticed some oil leaks in the garage from the area in which my wife parks her car ('04 Civic with '04 K20A2). I've been checking the engine oil regularily and it hasn't dropped. This morning I finally had a chance (aka got off my lazy ass!) put the car up on jack stands and go underneath and have a look.
To my surprise the leak was coming from the transmission case. The entire area around that transmission was caked with oil. I cleaned it up the best I could and got out a flashlight to see if I could pin-point the leak. It looks as if the oil seal between the transmission case and the right driveshaft assembly is leaking. We've noticed, during the last couple of months, that a fair amount of heat is coming up through the shift box and that the gears are "notchy".
If the transmission is low on oil, which judging by the amount of oil caked on around the transmission case it must be, I am sure this would case the transmission to get "extra" hot and this is the source of the heat coming up through the shift box. Also, low transmission oil is probably causing the notchiness in the gears.
The car currently has an Exedy Hyper Single, and we plan on replacing that with a Comptech flywheel, OEM disc, and OEM pressure plate (all of which we have in hand). During the clutch replacement, I am sure the oil seal mentioned above would be replaced.
Any thoughts?
Any thoughts?
IMO check the oil level with the transmission oil dip stick and add if needed.
#1 I would do.
If the oil smels bad (burned) have the oil changed.
#2 I would do.
Check car papers for warranty.
#3 I would do.
#1 I would do.
#2 I would do.
#3 I would do.
depending on where you get it replaced at.. most places will ask/ recommend replacing any seals while they are in there.. but if they dont recommend just buy the stuff and have them replace all the seals once they get in there.
what kinda of miles u have.. and could it be engine oil fluid from doing an oil change and not cleaning it up 100%
oh only was i talking about the oil plug leaking or not cleaned up after drain.. but the oil filter.. when u losing it to drain the oil and some gets on the engine block.. later on the oil will drip down and fly back when your driving.. im saying this cuz i work on toyotas.. yea im crazy , im a honda guy working at toyota.. but anyways. . on the 4 cylinder tacomas.. i had oil residue rite under the tranny.. i was like wtf.. only 15k on this truck and the seals bad.. no way.. i look around and i guess the person before didnt clean the oil filter area and oil drip down and flew back to the lowest point of the tranny.. i cleaned it all off and i found no leak.. even too the fly wheel cover off to feel for fluids since it was an automatic
but hard for me to say cuz no pics
I am almost 100% positive because I say oil leaking from the oil gasket between the transmission case and the driveshaft. Also, something needs to account for the notchiness in the gears and the heat coming up through the gear box. I believe that a low amount of tranny oil would contribute to these two issues.
Make sure it doesn't originate from the valve cover or oil cap area. Many an owner or technician has spilled oil when adding.
Hint: Oil always goes down.
