Transmission Fluid Change Interval
Has anyone used Gunk's motor flush before changing oil yourself in your high mileage motors, or have added Sea Foam to your oil afterwards at any time regardless of mileage? The marketing sounds good on the packaging. Please advise.
Here is what I do to my GST,S2K & Z06.
Engine Oil & Filter=5k Amsoil 0w30 & Wix
Clutch & Brake fluid=5k Prestone Dot 4
Clean Air Filter=5k K&N
Coolant=2 Years Prestone 50/50
Man Trans=Every Spring/10k)Amsoil MTF
Diff=Every Spring/10k Amsoil SG 75-110
IMO...Fluid is cheap.Hard parts are not.
\rlr
Carolina
\rlr
Carolina
I agree with this. MTF/MTL is the most subjective lube change there is on this car. It will give you very good feedback for when it has sheared too much and just doesn't shift as well as it used to. All the other fluids shear too, you just don't get the same kind of feedback as the transmission gives you.
Originally Posted by 90crvtec' timestamp='1178067337' post='10417366
Originally Posted by Money2536,May 1 2007, 03:08 PM
How often should I change Manual Transmission Fluid?
I keep it simple and I just dump the fluid once a year regardless of miles, it's cheap and easy maintenance IMO.
