Transmission Fluid Change DIY
#92
Is it possible to put too much oil into the transmission? Reason I ask is because when I had my clutch changed my trans was out and I figured why not just change the fluid by leaning the trans over and pouring it in. I put down exactly 2liters of the MTF in the black bottle.
Anyone know if there are any adverse effects putting in more than if you were to pump it?
#93
#94
Originally Posted by INTJ,May 7 2010, 06:46 PM
If you look at the old posts you will see a very long discussion on the trans pump and why it should be filled as high as possible, don't worry about it.
#95
1.6L in the manuals that I have and have seen.
It took me less than 2 seconds to find the links.
https://www.s2ki.com/forums/index.php?showtopic=599288
https://www.s2ki.com/forums/index.php?showt...=0&#entry596129
#99
Just to add my kudos. DON'T EVEN THINK about using some off-brand transmission fluid. We just had a complete transmission rebuild at 96k miles because the previous owner/dufus used non-standard transmission fluid at about 70k miles. He saved $70 and cost me $1500.
#100
Didn't the transmission feel funny during test driving?
