Transmission CLUNK
Old 09-16-2014, 04:31 AM
mikefifth's Avatar
Just picked it up from my local mechanic.
He says the noise is coming from the propshaft where it intersects the gearbox.
The only area where there was any play.
Old 09-17-2014, 06:19 AM
EOE
EOE's Avatar
Pretty sure I have play there as well but never thought anything of it for years now.
Old 09-18-2014, 07:29 AM
mikefifth's Avatar
I am going to chuck some money at a newer propshaft and see if this rectifies the issue.
Old 10-06-2014, 11:24 AM
EOE
EOE's Avatar
Keep us posted.
Old 09-16-2015, 12:23 AM
mikefifth's Avatar
Time to resurrect my own thread, nearly exactly 1 year on!
Anyway, I solved the issue with a second hand prop-shaft with around 50K on it.
Everything has been fine up until the other day. Same issue.
Driving along, brake, change down a gear, as soon as clutch engages there is a very loud clunk. I will attempt to get a video to show you.
One of my diff mounts is showing signs of deterioration however I a certain this is not to blame for the clunking noise (will be replaced soon).
Any ideas?
Old 09-16-2015, 05:33 AM
chefs2000's Avatar
I think it is the drive shaft cause mine has been doing this forever .. Probably normal .. The drive shaft is the only thing that sounds like that when I move it under the car ... Still does it and all mounts are Megan .. And did the diff collars ...
Old 09-16-2015, 06:38 AM
AE_Racer's Avatar
I get a clunk when I release the clutch from a stop and its free play in my diff (too much, worn out).
Old 09-16-2015, 12:17 PM
mikefifth's Avatar
Thanks guys. I will get a video up asap for confirmation.
I can make do the noise on cue now. Every down shift and I bring the clutch up really quickly in a snapping fashion. Also most like I'm shocking the drive train.
Old 09-16-2015, 12:57 PM
chefs2000's Avatar
I also have a ford 8.8 diff and it still makes the noise ..
Competitor9
08-04-2012 05:20 PM
Sabre
08-10-2011 05:35 PM
VTEC Racer
07-25-2008 10:48 AM
s2000Junky
05-17-2008 07:46 AM
legendr34
01-10-2002 12:40 PM
Quick Reply: Transmission CLUNK
