Transmission is acting funny... Please HELP
Old 05-10-2013, 08:38 AM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Starting with problem number one, you have a dragging clutch disc. (be sure you are pausing at least 2 seconds after pushing in the clutch to engage first)
dragging disc is caused by:
-incomplete disengagement, from low/dirty/airbound clutch fluid, clutch rod adjustment
-rusted spline
-broken disc or PP
there is nothing wrong with your transmission.
Old 05-10-2013, 11:47 AM
Joey2K's Avatar
If Billman and el S2000 are correct I would be the happiest S2K owner alive. A tip of the hat to you guys
I will get on this as soon as I get a chance, which is probably after my LSAT on June 10, if the problems persist I will come back to bug my S2000 family for a second round.
By the way: I did check how my transmission shifts while the car is off, it is not a nice smooth transmission, 3rd gear especially is almost worst than when the car is on. Reverse however seems fine
Old 05-10-2013, 11:53 AM
Billman250's Avatar
The trans is not supposed to be smooth with the car off.
Guaranteed clutch issue since your reverse issue disappeared.
Old 05-10-2013, 07:46 PM
dantediss's Avatar
When you switch to third from second dont shift at an angle go up to neutral for a second then up to third. Otherwise you grind gates and thats why its not smooth.
Old 05-11-2013, 03:53 AM
Billman250's Avatar
3rd gear "bump" is also a result of low rpm shifting. Bring it up to 5k each time and it will dramatically improve if not disappear all together.
Old 05-12-2013, 01:24 PM
jl56tc's Avatar
when my clutch disc was bad i had symptoms very similar to this ...... just a though
Old 05-29-2013, 01:53 AM
zgs2000hr's Avatar
ok, i have the same symtomps as number one problem in the first post.
so, did you solve your problems with this shifting issues?
blackv3ngenc
09-09-2014 09:54 AM
RedAt8
04-09-2009 08:27 PM
tntrac
11-23-2008 10:38 PM
nHobbes
06-24-2002 06:25 AM
MarkS2K
05-08-2001 05:41 PM
Quick Reply: Transmission is acting funny... Please HELP
