Is the tranny supposed to be so loud
Old 11-20-2011, 06:52 AM
starchland's Avatar
its nice to have a torque wrench but there are lots of people who change their motor oil and dont bother torqueing, just sayin...youll probably have a harder time getting at the diff fill bolt.
Old 11-20-2011, 08:47 AM
RacerXI's Avatar
I would not recommend using a torque wrench on the tranny or diff. There have been a few members that have broken off the trans drain bolt ear using a torque wrench. Replace the washer and tighten it.
Old 11-20-2011, 08:54 AM
trAP2's Avatar
Just looking to pick one up for future tranny fluid changes and diff fluid. Thanks alot MP2k
Old 11-20-2011, 08:55 AM
trAP2's Avatar
So you recomend tightening it without doing it to torque specs
Old 11-20-2011, 09:02 AM
drewz's Avatar
This doesn't make sense, why wouldn't you use a torque wrench? If anything you will overtighten it without a torque wrench b/c 33ft lbs isn't very much...
Now I wouldn't recommend using a torque wrench to remove the bolts, use a ratchet for that.
Old 11-20-2011, 09:26 AM
trAP2's Avatar
Im gonna do the change tomorow by picking up that torque wrench from autozone. Thanks for all the input guys
Old 11-20-2011, 09:34 AM
trAP2's Avatar
also i have the service record for the diff fluid change the previous owner did and it says they used 75-140. Is that ok or should i change it?
Old 11-20-2011, 11:12 AM
MP2k's Avatar
Thats good.
Old 11-21-2011, 04:43 AM
takeshi's Avatar
Oh and when i asked the previous owner if he changed the tranny fluid he said his mechanic told him the rear diff fluid was the tranny fluid
I'd consider everything the previous owner says to be suspect. Change all fluids.
Old 11-21-2011, 06:31 AM
Billman250's Avatar
Received 1,381 Likes on 828 Posts
^He is correct.
People use the wrong drive torque wrench for the job. They set the WRONG torque wrench too low in its range where it was not designed to operate and overtighten things.
Almost all the people that contact me about how to get a broken bolt out were using a torque wrench. Thw wrong one.
Quick Reply: Is the tranny supposed to be so loud
