Is the tranny supposed to be so loud
Old 11-18-2011, 09:19 PM
trAP2's Avatar
Default Is the tranny supposed to be so loud
Ok ive had my s2000 for 2 weeks now and i am really starting to notice how loud the transmission is. My main concern is when im moving in 1st gear at low speeds and decide to press the clutch to stop i hear 2 clanks they arent loud at all but when i press the clutch it goes dink dink really fast afterwards. I only hear it in 1st gear when im at low speeds. Its also pretty loud when putting it in first gear is that normal too. Gonna do a tranny fluid change aspa because i think the previous owner may have never done one and the car has 85k miles . He did change the diff oil 2k miles ago though. Thanks for the input guys.
Old 11-18-2011, 09:33 PM
drewz's Avatar
I bought my 03 with 22k miles and it does the clank clank since day one. Its usually only from 1st-2nd and 2nd-1st (changing gears, sounds a little different from your situation). I also changed the tranny fluid with the honda stuff and it did not reduce the noise. Once it warms up it will go away...
Old 11-18-2011, 09:35 PM
trAP2's Avatar
when the car warmed up it was better but still does the clanking in 1st gear only. I think im just being paranoid bc its prob normal.
Old 11-18-2011, 09:39 PM
trAP2's Avatar
Oh and when i asked the previous owner if he changed the tranny fluid he said his mechanic told him the rear diff fluid was the tranny fluid
Old 11-19-2011, 02:20 PM
s2cho's Avatar
its normal all s2000 do it
Old 11-19-2011, 03:11 PM
MP2k's Avatar
Thats not righ at all. I'd change both soon. The diff takes a 90wt(i think) GL5 gear oil and the trans is more of a 10w30 weight oil with modifiers in it. They are NOT interchangable.
Old 11-19-2011, 06:52 PM
trAP2's Avatar
yea gonna do the transmission fluid soon. Would a cheap click torque wrench work for the transmission pan bolt specs. I dont have one so i was gonna buy likc a 25 dollar one from autozone
Old 11-19-2011, 07:05 PM
MP2k's Avatar
If you can find one that reads low enough. All the cheap wrenches I've seen are on the upper end of the usable foot pound scale for this car. You want a wrench where the tq you use the most is close to the center scale of the wrench.
Old 11-19-2011, 07:14 PM
trAP2's Avatar
would one like this work?
http://www.autozone.com/autozone/acc...er=914018_0_0_
Old 11-19-2011, 09:54 PM
MP2k's Avatar
Yeah, that would be pretty good for a lot of the stuff on the car with that range. If you're just doing little stuff and don't want to spend much you can get by with that fine. I bought a one that came with a calibration certificate thats good for between 7-44ft/lbs just to have the piece of mind that it was right. It was also a lot more than the duralast and made in Germany
Quick Reply: Is the tranny supposed to be so loud
