Tranny Question
Well hopefully ill get the answer i want
I just Installed a Full Ap2 swap in my Ap1 (wiring/engine/tranny)
When it comes too the output shaft on the Ap2 tranny you need bigger bolts then the ones i have from my Ap1....
Question: Do i need too take the output shaft from my Ap1 tranny or could i just go buy the 6 bigger bolts Ap2 specific?....
I read a little and what realy sucks is needing the Honda special tool and needed new gaskets too swap the output shafts.....Guess if bolts dont fix the issue ill have too drop the tranny and install my Ap1 tranny
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![sadwavey.gif](https://www.s2ki.com/forums/images/smilies/sadwavey.gif)
Originally Posted by Slows2k,Feb 21 2010, 04:27 PM
You just swap the flanges, not the transmission secondary reduction shaft.
Number 5 from Ap2 needs bigger bolts then i have atm...But even if i order Ap2 bolts will they fit through the other shaft from my Ap1?
![](http://i7.photobucket.com/albums/y285/sleepingblacksi/Graphic.gif)
Originally Posted by Slows2k,Feb 21 2010, 04:33 PM
You need a socket to fit the nut on the flange, IIRC it is closer to 32mm And a impact wrench to remove it.
![lol.gif](https://www.s2ki.com/forums/images/smilies/lol.gif)
Thanks for your time its really appreciated i really wanna get my car running too enjoy it this spring
702onboost
12-06-2013 01:47 PM
