tranny is hard to shift in all gears
Old 01-24-2005, 01:03 PM
SM00TH976's Avatar
Default tranny is hard to shift in all gears
just today my car started getting really hard to shift, in all gears. i was thinking that maybe i needed to change the tranny fluid , but then i noticed something else weird. it's hard to describe this symptom, so bear with me. if i start from a dead stop in first gear, get going about 5-10 mph, and then push in the clutch with it still in first, the car gets a little jerky.
i was thinking the car needs new tranny fluid, the clutch bled, adjustment, or all of the above.
any suggestions? i tried searching but i couldn't really find anything. btw, the car has almost 80k miles on it.
Old 01-24-2005, 01:32 PM
FO2K's Avatar
Sounds like your clutch hydraulic dystem needs help. Could be either the master or slave cylinder going, or perhaps air in the lines. I suppose it could also be a warped disc/pressure plate.
I would start with bleeding the clutch hydraulics. Check for leaks.
Old 01-24-2005, 03:12 PM
SM00TH976's Avatar
ok well i just bled the clutch and changed the tranny fluid to mobil 1. i'll let you guys know if that fixes it.
Old 01-24-2005, 03:26 PM
oakfloor's Avatar
mobil 1 75-90w gear oil in your tranny? I use redline mt-90 with great results.
Old 01-24-2005, 03:32 PM
SM00TH976's Avatar
yeah, that's it. i know other stuff is better, but i have to drive for work tomorrow and i had to have it now, so i just went with the best stuff i could find in advance.
Old 01-24-2005, 03:38 PM
oakfloor's Avatar
yeah, you dont want to leave that in too long. I dont think it is made for trannys.. G.M. syncromesh oil is the buzz now, im told. BTW how does it shift now?
Old 01-24-2005, 03:41 PM
S2KenC's Avatar
You put Mobil 1 75w90 in your Tranny????
That is the gear oil that goes in the differential.
You're suppose to use MTF such as Honda OEM Manual Transmission Fluid, GM Syncrhomesh Friction Modified, Redline MT-90, etc,etc but not Mobil 1 gear oil.
Old 01-24-2005, 07:02 PM
SM00TH976's Avatar
haha, what a dumbass. like i said, i just grabbed what i saw. and apparently i am a total dumbass.
i'll pick up some gm synchromesh tomorrow. i hope the mobil 1 will be ok for 100 miles or so.
btw, the tranny still shifts like crap.
Old 01-24-2005, 09:23 PM
jackalope's Avatar
im having a similar problem w/ my car, it is incredibly ahrd to get into gear, and the clutch is very soft (ie the 1st 3/4's of the clutch are nothing, then maybe an inch to inch and a half of engagement)
should I maybe get the tranny fluid changed/taken a look at? would the honda dealership be the best palce for this (also, would it be a good idea to get the diff. fluid changed while I am at it?)
Old 01-24-2005, 10:28 PM
oakfloor's Avatar
yes
Quick Reply: tranny is hard to shift in all gears
