Tranny Fluid Drain Plug/Fill bolt help
I see that there are 3 different options for the Drain bolt here on this site.
http://www.hondaautomotiveparts.com/auto/j...ANSMISSION+CASE
Which one is the correct drain bolt.
Thanks
Thanks
and be sure to loosen/remove the filler bolt first, just in case something happens to it, ie. stripped thread or breakage. You don't want to be stuck with an empty transmission with no way to refill it.
