Tranny fill bolt spinning
Old 11-30-2008, 12:02 PM
skaterboyroland's Avatar
Default Tranny fill bolt spinning
I was changing my tranny fluid today.. And while putting the fill bolt back on(never used a torque wrench before). I must have screwed it too tight. Because now it only tightens a little bit then loosens.. Over and over. Does neone know what happened?
Old 11-30-2008, 01:39 PM
Slows2k's Avatar
You stripped the hole in the transmission case.
Old 11-30-2008, 01:40 PM
shotgunjimmy's Avatar
sounds like the threads a screwed. dont drive the car if you can avoid it, and get the hole re-threaded and flush the fluid out. youve probably got a few metal shards in there now. you're probably gonna need a new plug too.
Old 11-30-2008, 05:25 PM
Do u know about how much that costs to have them rethread it?
Old 11-30-2008, 05:32 PM
CKit's Avatar
Probably less than the cost of flatbedding it in to the dealer.
Old 11-30-2008, 05:34 PM
LOL.. Am I screwed? Less than $50?
Old 11-30-2008, 05:35 PM
and do i gotta take it to the dealer, or can I go to a normal shop?
Old 11-30-2008, 06:33 PM
armthehomeless's Avatar
Any shop should be able to thread a bolt, but you have to trust them, this involves metal shards being in your tranny.
Old 11-30-2008, 07:41 PM
JL01's Avatar
Sounds like you might have cross-threaded it and then tightened it down. I would try chasing the threads first on the trans, get a new fill bolt, and re-flush the tranny fluid.
Old 11-30-2008, 09:29 PM
CKit's Avatar
Just guessing, but by the time you get done with towing, threading, flushing, and fluid costs...
Maybe $200?
Quick Reply: Tranny fill bolt spinning
