TPS Going Bad or Something Else?
I had a track day this weekend and during the third session I got a CEL for TPS Circuit Low Voltage (P1022). It didn't affect the running of the engine on track but it did idle at about 1500 rpm when I came back into the paddock. I was able to reset it through OBD2 which also corrected the idle and it stayed off until I went back to full speed on track. Each successive session saw it appear sometime during the first or second lap, again with no symptoms. I reset it between each session and continued on my way. On my drive home it never reappeared.
Per the service manual I checked the throttle position at closed and WOT with the OBD2 and both were normal (6.3% and 88.9%). I also checked the voltage and resistance across the connector and sensor terminals. Again all in spec. I then ran it through the full range throttle with the OBD2 connected and found one spot where it dropped down to -0.4% where it should have been about 8%. Seems like this could be it. However, I started the car and ran it at this throttle position for about 15-20 seconds and was not able to reproduce the CEL.
Is this just a bad TPS or should I be looking for something else? Search results for this CEL code seem to be accompanied by several other codes which I did not get.
The previous owner replaced the TPS at some point with an aftermarket unit since the flanges have been buzzed with a Dremel. Not sure which brand/model. Is the Omnipower unit still the aftermarket replacement of choice?
Thanks in advance.
Thanks in advance.
Thank you for the response Bill.
Will the freeze frame data still be stored even though I cleared the CEL? If so, I will see if I can get it through the Torque app and bluetooth scanner I am using.
BTW. Majestic sells the new throttle body for $610. Ouch. That's pretty steep for a new potentiometer.
Thought I should update and (hopefully) close out this thread.
During the last 4 months of spirited street driving, the TPS CEL never came back. I also ran another track day this weekend and the TPS issue did not show itself there either.
To recap, I got repeated CELs on track for TPS circuit low voltage in May, which could be reset but eventually came back. I cleaned and calibrated the TPS and put dielectric grease on the contacts. No occurrences since then.
zzkamikazezz
08-21-2012 06:38 AM
The Reverend
06-21-2003 10:27 PM
