TPS,
TPS,
Hi, Im installing my Zex nitrous kit...... I have everything installed except one last step, I need to tap into the Stock Throttle position sensor. (TPS) there are 3 wires coming out of the sensor, power, ground and a signal wire i believe. My question is Which one is the Signal wire????
if anyone knows please please chime in!
thanks!
-Nate
thanks!
-Nate
One wire is ground, another is referance and the third is signal. I am on the road and don't have the ETM handy. You should be able to meter it. One will change and the other will not. You want the one that will change.
