Torque Specs for the Rear Brace & Gas Lines
I searched for 1 hour in the Service manual to try to find Torque Specs for both the Rear Brace inside the trunk, and also the Gas/Fuel line bolt that's inside the trunk on the drivers side and couldn't find anything. I even searched and read every post on torque specs on here and no one ever posted what torque specs those bolts are suppose to be in any of their suspension DIY or anywhere else that I could see.
So if anyone knows where to find the torque specs (what page in the manual) or knows them for the following, please post it up here...
1 bolt in the bracket that holds the Gas/fuel Line under the trunk liners on the driver side.
7 bolts for the Rear Brace bar.
I had to unbolt both of these items when I was installing my coilovers, as I wanted to make my life easier.
I ended up just putting it all back to a good hand tight, I figured if Honda didn't list them, that means they weren't that important, but I'm sure it must be listed somewhere.
Any help would be appreciated if anyone out there knows.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
manual shows 8 bolts for the rear bar inside the trunk. 22nm = 16ft lbs. Section 20 page 128 in my Helms manual.
i don't know which bolt your talking about for the gas line.
