torque specs?
torque specs?
well, i'm about to put in some springs tomorrow, just curious of what others have torqued the suspension bolts to, or what honda recommends, thanks!
i did a search a while back and copied the info on to a notepad.
i deleted last week, but luckily i didnt empty out the trash. here is what i got:
top nut 22
pair of 2 top bolts 36
bottom bolt 47
2 A-arm bolts 76
Front suspension:
Flange nuts that attach shock asembly to car (upper most nuts that stick into engine bay) - 49Nm/ 36lbf-ft
Damper bottom where bottom of shock bolts to lower a-arm: 64Nm / 47lbf-ft
Upper arm bolts: 103Nm / 75.9lbf-ft
Rear suspension:
Flange bolt at bottom of damper (the bolt that goes through the bottom of the upside down 'U'): 64Nm / 47lbf-ft
Upper arm bolts (if you touched them): 132Nm / 97.6lbf-ft
top nut 22
bottom bolt 47
2 A-arm bolts 76
Front suspension:
Rear suspension:
