Torque spec for 04-05 driveshaft bolts (pic)
The 04-05 uses bigger bolts for the driveshaft. Old spec is 24 Ft-Lbs for the smaller bolts....
A bud of mine has an 00-04 manual, but it's an early one, and Honda may have dropped the ball on this one. I find it hard to believe these monster bolts go to only 24 Ft-Lbs...I'll add this to the long list of incorrect crap in the Honda manual...
Anybody got a valid number?
Appreciated
Appreciated
Ok I've done some of my own calculating. You can use a torque wrench with a wobble socket.
I recommend 33-35 Ft-lbs of torque on the new bolts.
Slows2k....you'll see what I mean about these monsters
Yup....old bolts on the left, which have 6mm allen head, 8mm shaft, 2 different lengths used in 00-03
New bolts on the right, which have 8mm allen heads, 10mm shaft. One length for both ends of the driveshaft, unlike earlier cars...
