Top down, not all the way
Old 06-18-2007, 11:10 PM
B.Money's Avatar
Thumbs up Top down, not all the way
Hey guys, well I recently installed modifrys straps and did the whole office flooring hole fix thing that is supposed to stop wear to the top. I did this about 2k miles ago.
Anyway When i put my top down i hold it till it stops and makes a nice squish noise, but doesnt seem to go down as far as it used to.
Anything I should check out having to do with this problem or take out the rubber stuff in my top?? Thanks
Old 06-19-2007, 08:44 AM
Drkphnx's Avatar
make sure that one of the middle bars is pushed back when it is lowering, mine tends to go forward keeping it from setteling all the way down. So whenever i put the top down i push the bar back to guide it in place.
Old 06-19-2007, 09:38 AM
B.Money's Avatar
okay sweet ill check that out
Old 06-19-2007, 09:45 AM
s98d7fs's Avatar
If you've installed Modifry's convertible top fix you've already addressed the issue that drkphnx discribed. The new elastic straps shouldn't be wearing out in only 2,000 miles.
Old 06-19-2007, 09:52 AM
B.Money's Avatar
ah... ok i thought he was speaking of a different bar further back.
Old 06-20-2007, 05:36 PM
B.Money's Avatar
Old 06-20-2007, 06:40 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
That bar that the straps pull on should always be held back by hand when lowering the top. Even the straps don't pull that bar tight enough to allow the top to lower properly.
I teach this to all my customers, so they don't have top issues.
This applies to all s2ks, right up to 2007 cars that are brand new.
Old 06-20-2007, 06:51 PM
B.Money's Avatar
ah i see. Ill give this a try, makes sense. Cant think of anything else that could cause this problem, besides that rubber thing I put in to prevent holes.
Old 06-20-2007, 07:07 PM
tekstar's Avatar
how low is your soft top going that it isn't low enough for you?
http://www.modifry.com/products/ctf/details.htm
and just out of curiosity... can you explain "office flooring hole fix thing that is supposed to stop wear to the top" i have never heard of this before.
Old 06-20-2007, 08:01 PM
JeffForSale!'s Avatar
How can you reach the bar while lowering the top at the same time?
Quick Reply: Top down, not all the way
