Too much oil?
Too much oil?
Ok so after about 17,000 miles I finally get my next oil change to synthetic. I've added 3000 miles since, but recently I've checked the level and it was showing very low, about the last X. I checked in the morning before I drove off to school, so definitely the oil was settled. I went out afterwards to buy two more quarts of oil to add, and stupid me I didn't check the level at all when I adding it in. Now, when I checked it the next morning, the oil mark showed way to high on the stick! So I added too much! Is anything going to happen or should I jus simply get another oil change?
Honda says to look at both sides of the stick and then take the lower of the 2 readings. If you've over filled, you could blow a seal or two from the higher pressures.
How much extra is in there? Did you add both of the 2 quarts you purchased ?
If it's only overfilled a little (like less than 1/4 quart) I wouldn't worry about it. If it's overfilled more than that, just drain some out. There's no need to get a complete change.
Originally posted by vapors2k
that's not right. You check the level from the driver side of the dip stick, ie the higher level. The engine sits an angle, not perfectly straight.
Originally posted by HyperDimensions
Sorry for being oil iliterate, how do I do that?
