too much oil?
Old 06-26-2008, 11:16 AM
roflitzjinno's Avatar
Default too much oil?
anything wrong with too much oil? def dont want to mess up the car. its on H when the car is left over night, i have yet to check after the engine has been on. am i okay? or should i just change my oil and put in 5qts this time instead of trying to put in 5.1qts?
Old 06-26-2008, 11:18 AM
Nate4635's Avatar
.1 qt over?
trust me...you'll be ok
Old 06-26-2008, 11:21 AM
im not .1 qt over. when i check the oil level when the engine is COLD its ON the H.
Old 06-26-2008, 11:42 AM
Nate4635's Avatar
How much did you put in?
I really wouldnt worry, Im not sure what the indication is at that level of the dipstick, but on the X's I believe L is one qt low... If you try to scale that past where your oil level is I'm sure that will be a fraction of a quart...
Go hit Vtec a few times and you'll be right where you need to be
I've filled like 5.4-5.5 qt before...
Old 06-26-2008, 11:45 AM
iDomN8U's Avatar
Best time to check your old is on a level surface after it has sat for several hours.
With that said, overfilling your oil is NOT good, you can do serious damage (as documented here a few times)
When the engine is cold and it's on 'H' then your good
Old 06-26-2008, 11:55 AM
s2k dre's Avatar
i only put in 5 quarts and then add if needed.
Old 06-26-2008, 12:39 PM
so like youre saying. i let the car sit OVER NIGHT and checked it this morning and it was on the H and a bit above? a bit excessive? or should i not even worry about it? and its been like that for the past 3xx miles..
Old 06-26-2008, 02:27 PM
SheDrivesIt's Avatar
The dipstick looks like this:
H
X
X
X
X
X
X
X
X
L
If you are at the line below the H at the top of the X's then you are just full. If your oil shows just a little into the H, it's really fine. If the oil shows fully above the H, it is anywhere from a bit to high to far too high (depends how far above the H). All of this would be measured after engine is cool for a long time and sitting on level ground.
It really sounds like you are fine if you are just to the line below the H or just a little in to the H.
Got it?
Old 06-26-2008, 02:32 PM
Zeeb's Avatar
anywhere in the XXX's is fine riight? right now mines sitting i nthe middle exactl on flat ground and the engine is cool...
Old 06-26-2008, 02:46 PM
melonheadr6's Avatar
All of you that suggest checking the level when the engine is cold, please explain why Honda tells us to check the oil level at every fill up...
Quick Reply: too much oil?
